- To:
- Subject: [cgal-discuss] Circum center of 3 points
- Date: Tue, 09 Feb 2010 15:23:19 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=message-id:date:from:user-agent:mime-version:to:subject :content-type; b=vJq6ym/RYBvH0NhCDGaicKZrl5byPbLcj8f1/rJaZ9DeQXm1lBkoNaVE35S/IeLIrP 3nChMDJPuj2iWGsuYCcCziZNR1NOYUABJhZyj69MBfhqednd/Zz4zLbO/GZj4iXvLXpm 3DHuJurQ2hV7I3l0mLx80TgEhAou/tF/yRUxM=
Hello, I need to calculate the circum-center of three points (assuming they are not collinear). I saw that there is a construct in Circle_3 (from the manual):
My question is: Feeding the constructor with 3 points, would the center of the resultant circle be the circum-center of the triangle formed by these three points ? Also, is there any other construct available in CGAL that I can use ? Thanks /Priyank |
- [cgal-discuss] Circum center of 3 points, Priyank Jain, 02/09/2010
- Re: [cgal-discuss] Circum center of 3 points, Nikolas Engelhard, 02/09/2010
- Re: [cgal-discuss] Circum center of 3 points, vanderze, 02/09/2010
- Re: [cgal-discuss] Circum center of 3 points, Priyank Jain, 02/09/2010
- Re: [cgal-discuss] Circum center of 3 points, Michael Hoffmann, 02/09/2010
