cgal-discuss - Re: [cgal-discuss] Circum center of 3 points
  • To:
  • Subject: Re: [cgal-discuss] Circum center of 3 points
  • Date: Tue, 9 Feb 2010 15:16:56 -0600 (CST)
The best answer has already been given. You should use
CGAL::circumcenter(...)
But constructing a circle through the three points would
also work. min_circle_2 will not always work because
in some cases the smallest circle containing three
points will have only 2 of the points on its boundary.
-Evan
---- Original message ----
>Date: Tue, 9 Feb 2010 21:27:56 +0100
>From: Nikolas Engelhard
>To:
> My first thought: What else? I can't think of
> another interpretation.
> You could also use min_circle_2 which gives you the
> smallest circle so that all points lie within (or
> not outside?) this circle.
> (I guess they would be on the boundary, so that the
> distance to the center is exact the radius,
> everything else couldn't be defined
> exactly).
> Nikolas
> Am 09.02.2010 um 21:23 schrieb Priyank Jain:
> Hello,
> I need to calculate the circum-center of three
> points (assuming they are not collinear).
> I saw that there is a construct in Circle_3 (from
> the manual):
> Circle_3<Kernel> c ( Point_3<Kernel> p,
> Point_3<Kernel> q, Point_3<Kernel> r);
> introduces a variable c of type Circle_3<Kernel>.
> It is initialized to the circle passing through
> the three points.
> My question is: Feeding the constructor with 3
> points, would the center of the resultant circle
> be the circum-center of the triangle formed by
> these three points ?
> Also, is there any other construct available in
> CGAL that I can use ?
> Thanks
> /Priyank
