cgal-discuss - Re: Fw: [cgal-discuss] a question about macro CGAL_USE_GEOMVIEW
  • To:
  • Subject: Re: Fw: [cgal-discuss] a question about macro CGAL_USE_GEOMVIEW
  • Date: Sat, 20 Feb 2010 22:54:53 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=B2WOBXUB+egI4+W7+CqTOaqQ8Kh8IAtYnJJV2/8xRJRiFAGRpbok98rCtTIxbamqUj ex44HiGVawSxKvtBFMhWrf06D5u4VwA+g85s3UBSySgtRiwpVDwYtrIl5ezaIE84jT7K RDal8BUtxzfmffORlPKMDVRExISunp6qWY91k=
GEOMVIEW is one of CGAL's visualization methods , the problem is that it doesn't work in windows
you'd better start with demos that use Qt4 (assuming you don't have Qt3)
Regards,
Mohamed Yousef
On 20 February 2010 21:29, Sheikh Faridul Hasan <> wrote:
Did you try http://www.geomview.org/download/ ?
On Sat, Feb 20, 2010 at 4:33 PM, mycug <> wrote:
dear Laurent,
when I build Triangulation_3_demo.cpp in ms2005 , I found the macro CGAL_USE_GEOMVIEW didnot be defined。 Does  cgal need install GEOMVIEW?if yes ,how to do it?
thank you。
mycug from Wuhan。
