- To: <>
- Subject: [cgal-discuss] pass vertex index when constructing alpha shape?
- Date: Fri, 26 Feb 2010 12:47:23 +0100
Dear all, again :)
I have a number of points, with each having certain properties (like
temperature, etc..).
I can add an index to my alpha shape as described by
https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2008-02/msg00157.html, but
only after the alpha shape has been created. Therefore I kind of loose the
information connected to each point. I need to recalculate the alpha shape
several times in the changing arrangement of points.
Is it possible to construct the vertices in the alpha shape already with the
index they have in my simulation?
Thank you very much for your help!
max
______________________________________________________
Max Eggersdorfer
Particle Technology Laboratory, ETH Zürich
Sonneggstrasse 3, ML F 18
CH - 8092 Zurich (Schweiz)
+41 44 632 39 52
- [cgal-discuss] pass vertex index when constructing alpha shape?, Eggersdorfer Maximilian, 02/26/2010
- Re: [cgal-discuss] pass vertex index when constructing alpha shape?, Daniel Duque, 02/26/2010
