cgal-discuss - [cgal-discuss] Re: Assertion thrown -- wrong rounding
  • To:
  • Subject: [cgal-discuss] Re: Assertion thrown -- wrong rounding
  • Date: Sun, 28 Feb 2010 12:04:55 -0800 (PST)
Hi,
I've build the CGAL lib with macport. A "tool" for mac users to easily compile lib's.
The problem is you can't adjust the compile proces.
I will contact the port community about this problem.
Tanx for your advise!
Bardo
2010/2/26 Laurent Rineau (GeometryFactory) [via cgal-discuss] <[hidden email]>
On Friday 26 February 2010 11:11:09 BardoB wrote:
> Hi,
> I have the same problem.
> gcc --version:
> i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build 5646) (dot 1)
> Copyright (C) 2007 Free Software Foundation, Inc.
> This is free software; see the source for copying conditions.  There is NO
> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> cat CGALConfig.cmake | grep frounding:
> set(CGAL_CXX_FLAGS_INIT "-pipe -arch x86_64 -arch i386  -frounding-math
> -fno-strict-aliasing" )
> cat CMakeLists.txt | grep frounding:
> message( STATUS "Using gcc version 4 or later. Adding -frounding-math" )
> uniquely_add_flags( CGAL_CXX_FLAGS "-frounding-math" )
> Is there a sollution known?
For some reason, the flag -frounding-math is not used. Try recompile CGAL:
  make clean
  make VERBOSE=1
and check the flags. If you compile a program, please also use make VERBOSE=1
to check the compilation flags.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
View this message in context: Re: Assertion thrown -- wrong rounding
