cgal-discuss - Re: [cgal-discuss] 3D triangulation with scattered points
  • To:
  • Subject: Re: [cgal-discuss] 3D triangulation with scattered points
  • Date: Mon, 01 Mar 2010 15:05:31 +0100
Edoardo Milotti wrote:
in my application I triangulate large sets of randomly scattered points (in 3D), and I must keep track of all of them. Since insertion of the whole vector of points also shuffles them at random to avoid degeneracies, I cannot use this direct method, and I have to insert them one by one to keep the original order. Since in my case the points are in general position and I don't have to deal with degeneracies I would like to use the faster insertion of the whole vector: is there a way to disable the internal shuffling?
Edoardo Milotti
Hello,
The insert by range method has nothing to do with geometric degenerate cases. The random shuffle of the input points is made to have a kind of uniform random distribution of points in the space. Then a spatial sorting algorithm is applied to input points so that upon insertion of an element, a cell of this element can be used as an hint to insert the next element (which makes the speed up).
Thus even without the shuffling, points are sorted and not inserted in the range order.
You can associate to each inserted point an index so as to keep track of them. We should have an integrate solution for this kind of problem in a future release of CGAL (the one after 3.6).
In the meantime, you could refer to this post https://lists-sop.inria.fr/sympa/arc/cgal-discuss/2010-01/msg00004.html
for a temporary solution.
S.
Edoardo Milotti
Address:
Dipartimento di Fisica dell'Università di Trieste
and I.N.F.N. - Sezione di Trieste
Via Valerio, 2
I-34127 Trieste, Italy
e-mail:
<mailto:>
phone: +39 040 558 3388
fax: +39 040 558 3350
http://www.ts.infn.it/~milotti/index.html
