cgal-discuss - Re: [cgal-discuss] Help
  • To:
  • Subject: Re: [cgal-discuss] Help
  • Date: Tue, 9 Mar 2010 08:01:04 +0000
  • Importance: Normal
  • Sensitivity: Normal
Hi Javed,
The point cloud formats that can be read in the surface reconstruction demo in CGAL are:
XYZ,
OFF,
PWN (homemade format 3d point + normals).
Best,
Nader.
Nader Salman
PhD candidate in Computational Geometry
Geometrica - INRIA Sophia
Date: Tue, 9 Mar 2010 04:30:19 +0530 (IST)
To: <>
Thanx for reply,
  Could you plesase tell me what are the required formats of point cloud data that can be used in surface reconstruction or which format does MATLAB supports in order to reconstruct surfaces. I use Laser Scan Arm for digitizing surfaces. How can I export this point cloud data to the  MATLAB?
Please  Help
Javed Aalam
To:
Sent: Mon, 8 March, 2010 5:05:51 PM
Hi Javed,
You may start with the "Surface Reconstruction from Point Sets" chapter of CGAL documentation
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_reconstruction_points_3/Chapter_main.html
Best regards,
Laurent Saboret
javed aalam wrote:
Hello everybody,
  I m Javed , I am new in this group.  I m doing MS. I want to do my research thesis in Surface reconstruction from point cloud data. I have got CMM and Portable Laser Scan Arm. So how can I use this point cloud data for surface reconstruction? How can I play with this point cloud data. What are the available interfaces (Matlab, C programs or etc) for surface reconstruction?  Please help me I have to submit my research proposal soon. I will b realy great to u for your help.
  Waiting for your precious replies.
With Regards,
Javed Aalam
M.S(Industial Engg.)
King Saud University
Riyadh, K.S.A.
The INTERNET now has a personality. YOURS! See your Yahoo! Homepage.
Ce courrier électronique et toutes les pièces éventuellement jointes qu’il contient sont CONFIDENTIELS et destinés exclusivement à l’usage de leur destinataire. Si une erreur de transmission ou une adresse erronée a mal dirigée ce courrier, merci d’en informer l’expéditeur en lui faisant une réponse par courrier électronique dès réception. Si vous n’êtes pas le destinataire de ce courrier, vous ne devez pas l’utiliser, le conserver, en faire état, le distribuer, le copier, l’imprimer ou en révéler le contenu à une tierce partie.
Ce courrier électronique est à usage strictement informatif et ne saurait engager de quelque manière que ce soit INFOTERRA France SAS, ni ses filiales.
This e-mail and any attachments hereto are CONFIDENTIAL and intended solely for the use of the addressee. If you have received this e-mail in error please send it back to the person that sent it to you.
If you have received it in error, please notify the sender by return email. If you are not the addressee of this email, you must not use, keep, disseminate, copy, print or otherwise deal with it.
This email is for information only and will not bind INFOTERRA France SAS in any contract or obligation, nor its subsidiaries.
Your Mail works best with the New Yahoo Optimized IE8. Get it NOW!.
