Re: [cgal-discuss] How to install CGAL into MacOS and compile programs in Xcode?
- To: cgal-discuss <>
- Subject: Re: [cgal-discuss] How to install CGAL into MacOS and compile programs in Xcode?
- Date: Tue, 9 Mar 2010 16:10:36 +0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=GXdDVEkH4MbGkyNN7cEbOpASqJ7IhV+IdcDApXsXch0Td9X2bwroTQ+OaEYDViLlSq uySSanBSXV4MdYEirxhHHIAdIDNH4HJaqXFZXn/NCb38JQL/ZH9lL+ED5WL67/ue7m/I c2w4qo6aFYWNxuvh7qn6rQ1ixPjnbavfW3/LM=
2010/3/9 Stephane Tayeb <>
Hi,
I personnaly proceed as follows:
Installation: same as you
Compile in Xcode:
1. Go to example directory (e.g. examples/Voronoi_diagram_2/)
2. Generate Xcode project using cmake: $cmake -GXcode .
3. Open Xcode project
4. Compile using Xcode (note: I change compiler from gcc-4.0 to gcc-4.2 in Xcode)
NB: you could also have a look at this script 'scripts/cgal_create_cmake_script' which could create a CMakeLists.txt for your own project if you don't want to start from an existing example folder.
Best,
Stéphane.
Thanx, Stephane!
One thing - there is need to change wirking directory.
Choose in menu: "Project" -> "Edit Active Executable ..." ->
"Set the working direcoty to:"
+ "Project directory"
That's all! :)
- [cgal-discuss] How to install CGAL into MacOS and compile programs in Xcode?, Serebryakov, 03/09/2010
- Re: [cgal-discuss] How to install CGAL into MacOS and compile programs in Xcode?, Stephane Tayeb, 03/09/2010
- Re: [cgal-discuss] How to install CGAL into MacOS and compile programs in Xcode?, Антон Серебряков, 03/09/2010
