- To:
- Subject: Re: [cgal-discuss] can the constrained triangulation constrains the boundary
- Date: Thu, 11 Mar 2010 10:29:15 +0100
On 11/03/2010 08:21, zhoufang8811 wrote:
Hi,
I have a promble in Triangulation, can the constrained triangulation
constrains the boundary that only triangulating in/out the boundary?
2010-03-11
zhoufang8811
CGAL triangulates the convex hull of the points even in presence
of constraints. If your constraints partitition the plane in
areas that you interpret as inside/outside, you have to traverse
the triangulation and mark faces as being inside outside.
The class Triangulation_face_base_with_info_2 will be helpful
for storing the markers.
best regards,
andreas
- [cgal-discuss] can the constrained triangulation constrains the boundary, zhoufang8811, 03/11/2010
- Re: [cgal-discuss] can the constrained triangulation constrains the boundary, Andreas Fabri, 03/11/2010
- [cgal-discuss] Re: can the constrained triangulation constrains the boundary, zhoufang, 03/12/2010
