cgal-discuss - [cgal-discuss] 3D Mesh Generation - Curvature_size_criterion
  • To:
  • Subject: [cgal-discuss] 3D Mesh Generation - Curvature_size_criterion
  • Date: Thu, 11 Mar 2010 10:22:01 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:date:message-id:subject:from:to:content-type; b=YYGE0D7L2jKqc2pt0V/OUwo2AhMOk2vIFCimFx4FdT6bvMBUkx4mo3V+hzF9Kia8NN G/eNA1lkR0O4LYvYgi8SzSpSkiayleVvFubvNKWXSpbH4Y6y+aJNY33CuhcItQSUtSTY Dtc5X+nxe/THpg09nYwIJsHkk2cCodIsLo+6I=
Hi,
I would appreciate it if someone explains how the curvature criterion is enforced in Curvature_size_criterion class (in mesh_standard_facet_criteria.h)
As I understand, in the "do_is_bad" member function of Curvature_size_criterion class, the distance between circumcenter of facet and "facet surface center" is calculated to ensure it does not exceed the allowed maximum value.
The following are ambiguous to me:
- Is this criterion trying to put a bound on the distance between the facets and the "mesh domain" surface? (in my case "mesh domain" is defined by a polyhedron)
- Is the circumcenter located in the plane of facet and "facet surface center" located on the "mesh domain" surface?
Also, any hint to a document that discusses this in more details is highly appreciated.
Thanks,
-Ramin
