- To:
- Subject: Re: [cgal-discuss] Error in a file that does not use CGAL classes
- Date: Thu, 11 Mar 2010 18:32:49 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=FB6Li380i9eT6Ad0iM4HNoUKDUiI4hydIKzxvdZPBOg9Jk2jL3/gtuULuYRan+6sal XuSuBhJrCYpD9xbQz9AmyzBY0/hdb4iQHRDHEYeaJ0+aZ1IIi8I6Ld/eKA621W6ko2LP r+QFFYv02l1oeknHf9o5U7nBEvYOS+BYeLHwA=
I had a "similar" issue with CGAL3.5.1 and Qt4.3.1 in my project. My code compiled on GCC but Visual Studio could not compile it.
Reordering the #include directives might solve the problem. Try putting CGAL header files at the beginning and the rest of the header files after.
-Ramin
On Thu, Mar 11, 2010 at 6:15 PM, Laurent Rineau (GeometryFactory) <> wrote:
Le Jeudi 11 Mars 2010 21:26:31, Nicholas Mario Wardhana a écrit :
> Hi all,
> We just used CGAL in our project to search for some closest neighbours
> of each waypoint. The code is adopted from :
> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Spatial_searching/Chap
> ter_main.html#Subsection_57.3.5
> 1>------ Build started: Project: GameFactoryDemo, Configuration: DebugWhy the way, what sort of open source project are you working on? That seems
> Win32 ------
> 1>Compiling...
> 1>GameScene.cpp
interesting.
Laurent Rineau, PhD
- [cgal-discuss] Error in a file that does not use CGAL classes, Nicholas Mario Wardhana, 03/11/2010
- Re: [cgal-discuss] Error in a file that does not use CGAL classes, Laurent Rineau (GeometryFactory), 03/12/2010
- Re: [cgal-discuss] Error in a file that does not use CGAL classes, Ramin H, 03/12/2010
- Re: [cgal-discuss] Error in a file that does not use CGAL classes, Nicholas Mario Wardhana, 03/12/2010
