- To:
- Subject: Re: [cgal-discuss] about the libs of taucs
- Date: Tue, 16 Mar 2010 16:38:11 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=YQZZlhsVyKtHWxh1soUqacZDIxQMFYsCdM2UIiok3fnQ5/kqx0fp3/Yc/7LfUTShEL ZIfKKAjI9xuQpZfi5lKclcobWOoQaGwHMsyX6zrSaTOacDHaI9oFQ7lehwHM6IMS+KBg 7+C/N+zaTYKV3co/aBtqXP7bKIff57NhbjAYw=
I suggest you to use the installer of CGAL 3.6-beta-1.
Don't worry about the word "beta" version. it's only "beta" for the newly featured algorithms. the "old" codes are still robust and working. --- Personal experience. :)
best regards
shuchu
On Tue, Mar 16, 2010 at 3:24 AM, <> wrote:
When I installed CGAL3.5 on my pc with 32 bit winxp, I chose vc90 since I am
using
vs2008. But, under ..\auxiliary\taucs\lib, what I got is libs for vc2005, such
as
vcf2c-vc71-mt-gd.lib. As a result, the example of Ridges_3 cannot be linked
correctly.
While, under ..\auxiliary\gmp\lib, what I got is exactly for vs2008, such as
mpfr-vc90-mt.lib
What should I do? thanks!
- [cgal-discuss] about the libs of taucs, lienlee, 03/15/2010
- Re: [cgal-discuss] about the libs of taucs, Laurent Saboret, 03/16/2010
- Re: Re: [cgal-discuss] about the libs of taucs, lienlee, 03/16/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] about the libs of taucs, Shuchu Han, 03/16/2010
