cgal-discuss - Re: [cgal-discuss] using Geomview with CGAL
  • To:
  • Subject: Re: [cgal-discuss] using Geomview with CGAL
  • Date: Tue, 16 Mar 2010 16:32:00 +0800
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=X/nkCBXZr4HO7Ab22jtXFi7+wBXWiZWuhX7v/L8OYvotAx5fNFMC5Xzyi0J1KiLgz/ h/zu0yAxGRzFIPV8Y9y5k1PGTXqqUMu8PIDMp87kIPMPkRIIG/n3jVdIM+IhQchkhFA+ tDRsW2ciVLhuzzWz16RdqSxFfJ2L8QKrJU4dk=
Hi,
As i know, geomview need some libs of linux system, I/O and X11 libs, and seems no one have time to deploy it into Microsoft system until now.
If you only care the IDE, I think "Code Blocks" and "Eclipse C++" maybe alternative choices. I once successful use "CodeBlocks + Cygwin" to let my codes invoke the the geomview related header files in CGAL. However, you need to compile and install CGAL under cygwin.  This is a little trick that you can use an IDE installed windows but use the GNU c++ compiler installed in cygwin).
For the mesh viewer, I recommend you to use "MeshLab". Also you can write a mesh viewer by yourself.  You can use a specific file format, such as ".OFF" ".OBJ" format or the one defined by yourself, to exchange the information between your programs and the mesh viewer.
help it useful.:)
best regards
shuchu
On Mon, Mar 15, 2010 at 5:26 PM, Youssef ALJ <> wrote:
Hi,
Ah no, but here's the answer in your question... ;-)
Actually, i'd like to use Visual studio (so in windows enviroment) with  both cgal and geomview.
Is there any trick to make this feasible?
Best regards,
Youssef ALJ
Date: Sun, 14 Mar 2010 21:42:54 -0700
To:
Hi,
Did u  install the CGAL and Geomview in the same compiler environment, i mean  MS9.0 c++ compiler under Windows or GUN C/C++ compiler under Ubuntu/ cygwin ?
best regards
shuchu
On Sun, Mar 14, 2010 at 9:21 AM, <> wrote:
Hi,
I'm pretty sure that the issue about using geomview with CGAL was already asked
before. But recently, i discovered that geomview could be installed on
windows platforms using unix-like systems (portable ubuntu or cygwin...).
To configure CGAL, i tried to fill the variable CGAL_USE_GEOMVIEW in cmake gui
with the path to goemview binaries, but i didn't work out.
Is it correct what i did? is there any additional setting i missed to do?
Any suggestion is helpful.
Best regards,
Youssef ALJ
Hotmail: Powerful Free email with security by Microsoft. Get it now.
