cgal-discuss - Re: [Fwd: [cgal-discuss] Tetrahedron-Polyhedron problem]
  • To:
  • Subject: Re: [Fwd: [cgal-discuss] Tetrahedron-Polyhedron problem]
  • Date: Wed, 17 Mar 2010 13:40:57 +0100
wrote:
Thank you for the fast answer.
This is actually mentioned in the manual, and this is why I'm surprised!
how could the program say they are halfedges while they're connected from
2 sides?
halfedges in polyhedron have a method is_border() (it checks whether the halfedge as an incident facet).
Anyone please, could you please tell me how to convert 2 halfedges to an
edge?
There is no edge object. Please have a look at
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Polyhedron/Chapter_main.html#Section_23.2
I guess this would solve the problem and make my polyhedron closed!
In the example I sent you, the method is_closed() returns true.
Thank you,
Samer Afach
wrote:
Thanks for the answer.
But if I have to do this check manually, what's the purpose of the
Polyhedron::is_closed() function? I thought this function is capable of
doing this.
And if I'm going to check this manually, why should I use the
incremental
builder? one then can create triangles from points, which is a lot
simpler
to implement (like my first example I wrote in this e-mail), and then do
this check manually (while the check Polyhedron::is_closed() fails to
give
the right answer).
Could you please explain what is_closed() function does?
I am not an export of Polyhedron, I was not aware this function exists.
I had a look at the code for the is_closed, and it is checking that no
halfedge is on the boundary.
and why I'm
supposed to use the incremental builder for my task if I'm to do this
check manually?
Is there a shorter way to create my polyhedra than I'm taking?
Thank you,
Best regards,
Samer Afach
wrote:
Thank you so much for your answer.
but I still have 1 unclear issue. I've seen that that example creates
a
triangle, meaning a surface. What if I want to create a closed
polyhedron
(like a cube or a tetrahedron)? as a general question I would like to
ask,
is CGAL able to form a "closed" polyhedron and know that it's closed
in
an
automatic manner? because as I drew in my first problem, I created the
surfaces, but the program wasn't able to detect that it's a closed
polyhedron (while it's of course closed, since I followed the same
simple
point-structure of the example).
How can I tell CGAL to confirm (not check) that my polyhedron is
closed,
so that if I use the check function Polyhedron::is_closed() I would
get
the right answer?
Is the incremental builder the right tool for that task?
Thank you again,
Best Regards,
Samer Afach
First note that Polyhedron can only be used to represent one or more
surfaces.
In the example joint, I manually create a tetrahedron to show that the
incremental builder add faces in a clever way (halfedge are reused when
you add a facet). The number of halfedges is 12.
To know if your surface is closed, you can rely on the theorem of
classification of surface and the Euler characteristic
(http://en.wikipedia.org/wiki/Euler_characteristic).
The Euler characteristic is 2 for each closed surface encoded by the
polyhedron (the for each is really important here).
S.
Hello,
From what I understand you probably need to use the
Polyhedron_incremental_builder_3.
Have a look here for the documentation (there is an example at the
end
of the page)
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_incremental_builder_3.html
S.
wrote:
Dear programmers,
I've drawn this question but no one has given me an answer. I would
really
appreciate it so much if someone could even give me a hint to solve
this
problem. It's really very important for me.
Thank you in advance,
Sincerely,
Samer
---------------------------- Original Message
Subject: [cgal-discuss] Tetrahedron-Polyhedron problem
Date: Fri, March 12, 2010 5:15 pm
To:
Hello :),
I'm starting to create some simple polyhedra in order to go to
bigger
applications, and so I'm trying to understand how this library works
with it.
I have a problem, the problem is that I'm failing to create 4
triangles
and form a tetrahedron from them. I'm avoiding using the function
Polyhedron::make_tetrahedron(...) because my aim in the future is
creating random polyhedra by combining triangles and check whether
they
are closed and fulfill some conditions. Here's my program:
#include <CGAL/Homogeneous.h>
#include <CGAL/Polyhedron_traits_with_normals_3.h>
#include <CGAL/Polyhedron_3.h>
#include <iostream>
#include <algorithm>
using namespace std;
struct Normal_vector
template <class Facet>
typename Facet::Plane_3 operator()( Facet& f) {
typename Facet::Halfedge_handle h = f.halfedge();
// Facet::Plane_3 is the normal vector type. We assume the
// CGAL Kernel here and use its global functions.
return CGAL::cross_product(
h->next()->vertex()->point() - h->vertex()->point(),
h->next()->next()->vertex()->point() -
h->next()->vertex()->point());
typedef CGAL::Homogeneous<int> Kernel;
typedef Kernel::Point_3 Point_3;
typedef Kernel::Vector_3 Vector_3;
typedef CGAL::Polyhedron_traits_with_normals_3<Kernel> Traits;
typedef CGAL::Polyhedron_3<Traits> Polyhedron;
typedef Polyhedron::Halfedge_handle Halfedge_handle;
int main() {
Point_3 p( 1, 0, 0);
Point_3 q( 0, 1, 0);
Point_3 r( 0, 0, 1);
Point_3 s( 0, 0, 0);
Polyhedron P;
//P.make_tetrahedron( p, q, r, s);
P.make_triangle(p,q,r);
P.make_triangle(p,r,s);
P.make_triangle(p,s,q);
P.make_triangle(q,s,r);
if(P.is_closed())
cout<<"It's closed"<<endl;
if(P.is_pure_trivalent())
cout<<"Trivalent"<<endl;
std::transform( P.facets_begin(), P.facets_end(),
P.planes_begin(),
Normal_vector());
CGAL::set_pretty_mode( std::cout);
std::copy( P.planes_begin(), P.planes_end(),
std::ostream_iterator<Vector_3>( std::cout, "\n"));
return 0;
I copied this program from a sample in the manual. What's confusing
me
is that when I create a tetrahedron using the make_tetrahedron
function,
the conditions work fine, but I can't get the same output when
creating
a tetrahedron by "connecting" 3 dimensional triangles. I was even
careful having the same output as the example (same order for the
norms)
Could anyone please tell me why that's happening, and I would
appreciate
it so much if someone also could apply the function
Polyhedron::is_tetrahedron(Polyhedron::Halfedge_handle) also,
because
I
failed to do it because I didn't know how to get the right call for
Halfedge_handle.
Sincerest regards,
Samer Afach
Institute of computational physics, University of Stuttgart
