- To:
- Subject: Re: [cgal-discuss] Polyhedra visualisation
- Date: Thu, 18 Mar 2010 16:20:00 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=kGKyI4OOdoSiDDzIVJwMgerHS/IUXrCGJ9Xl+4CR1SVfNk5KQeHmtCHXQCT4sJ+mPn CfyaeOsg7/5JOPxW50I/PIhbtzYPu6KV94CmWR57Az6Q+Qr4lr1L4atkI/9U/IG+1eLG X83tsQpTKEvbuDRZXTbb2ys1bpM2EyYujI7WA=
Hi Samer,
One way that requires minimum programming is to write the polyhedron to an .off file. Then visualize the .off file with Geomview (http://www.geomview.org).
Or if you want to visualize the polyhedron in your own code, you may look for sample code in polyhedrom demo (CGAL\demo\Polyhedron)
Regards,
-Ramin
On Thu, Mar 18, 2010 at 4:05 PM, <> wrote:
Hello programmers,
I have a question. What's the fastest way for visualising a polyhedron
object? is there some program that I could give data from the object to
see how good my polyhedron looks like? windows or linux is OK for that
purpose.
Thank you,
Regards,
Samer Afach
- [cgal-discuss] Polyhedra visualisation, samer, 03/18/2010
- Re: [cgal-discuss] Polyhedra visualisation, Ramin H, 03/18/2010
- Re: [cgal-discuss] Polyhedra visualisation, samer, 03/19/2010
