- To:
- Subject: Re: [cgal-discuss] Polyhedra visualisation
- Date: Fri, 19 Mar 2010 00:03:32 +0100
- Importance: Normal
Thank you so much :)
> Hi Samer,
> One way that requires minimum programming is to write the polyhedron to an
> .off file. Then visualize the .off file with Geomview (
> http://www.geomview.org).
> Or if you want to visualize the polyhedron in your own code, you may look
> for sample code in polyhedrom demo (CGAL\demo\Polyhedron)
> Regards,
> -Ramin
> On Thu, Mar 18, 2010 at 4:05 PM,
> wrote:
>> Hello programmers,
>> I have a question. What's the fastest way for visualising a polyhedron
>> object? is there some program that I could give data from the object to
>> see how good my polyhedron looks like? windows or linux is OK for that
>> purpose.
>> Thank you,
>> Regards,
>> Samer Afach
>> You are currently subscribed to cgal-discuss.
>> To unsubscribe or access the archives, go to
>> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] Polyhedra visualisation, samer, 03/18/2010
- Re: [cgal-discuss] Polyhedra visualisation, Ramin H, 03/18/2010
- Re: [cgal-discuss] Polyhedra visualisation, samer, 03/19/2010
