- To:
- Subject: Re: [cgal-discuss] Can I get handle out of an iterator/circulator?
- Date: Sat, 20 Mar 2010 19:47:10 +0100
Le Samedi 20 Mars 2010 16:29:15, J. Jin a écrit :
> Dear all,
> I want to know whether there is a general way to convert an
> iterator/circulator to a handle.
Most CGAL iterators/circulators type are castable to the corresponding handle
implicitly.
> Consider the following example.
> I want to traverse in a mesh with type Triangulation_data_structure_2 for
> some vertex in a breadth first search manner.
> I start with a vertex(suppose I have its handle), so I can use circulators
> to check all its neighbors.
> But... here is the problem. How can I continue?
> The method incident_vertices needs an input of type Vertex_handle, but what
> I got is of type Vertex_circulator.
You can use circulators and iterators as if they were handles.
Laurent Rineau, PhD
- [cgal-discuss] Can I get handle out of an iterator/circulator?, J. Jin, 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Karl Gaize, 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Laurent Rineau (GeometryFactory), 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Jiongxin Jin, 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Laurent Rineau (GeometryFactory), 03/21/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Jiongxin Jin, 03/21/2010
