- To:
- Subject: Re: [cgal-discuss] Can I get handle out of an iterator/circulator?
- Date: Sun, 21 Mar 2010 14:02:03 +0100
Le Samedi 20 Mars 2010 20:40:04, Jiongxin Jin a écrit :
> Thank you for your clarification, Laurent.
> Actually, that is exactly what I did after reading the source code a bit.
> Just because I cannot find any document, I am not sure whether it is
> the correct way to do.
> (For example, future versions of CGAL may change the implementation of
> handles.) Now I think I just cast them to handles anyway. :)
That is said from time to time in the manual, for example here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_2/Chapter_main.html#Section_33.4
There is probably a better way to documentation that implicit conversion. As
a
user (and reader of the manual), do you have a suggestion how we could
improve
that?
Laurent Rineau, PhD
- [cgal-discuss] Can I get handle out of an iterator/circulator?, J. Jin, 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Karl Gaize, 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Laurent Rineau (GeometryFactory), 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Jiongxin Jin, 03/20/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Laurent Rineau (GeometryFactory), 03/21/2010
- Re: [cgal-discuss] Can I get handle out of an iterator/circulator?, Jiongxin Jin, 03/21/2010
