- To:
- Subject: Re: [cgal-discuss] scattered point cloud volume
- Date: Sat, 20 Mar 2010 18:50:02 -0500
Hi, well i have a couple ideas. first i DO think you can manage point clouds in cgal based upon my readings, but i'm not an expert at that... here's another idea: if you have a point cloud, can you convert it to a voxel image? the idea is to generate a 3D logical matrix where you have 'ones' for each 'point' in the cloud, and zeros elsewhere (easy in matlab). then you can use any of a number of morphological operations (such as dilate)... with blurring, and/or (even more powerful) level-set methods to 'fill-in' the gaps in the cloud to create your solid object. Once you have the solid 'filled in' object, then you can isosurface in matlab, or use the image-based 3-D mesh generation methods in CGAL to create a surface or tet-mesh. hope that helps! best, todd -- oo-o--o---o----o-----o------o-------o------o-----o----o---o--o-oo Todd C. Doehring, Ph.D. Assistant Professor School of Biomedical Engineering Drexel University oo-o--o---o----o-----o------o-------o------o-----o----o---o--o-oo Sheikh Faridul Hasan wrote:
- [cgal-discuss] scattered point cloud volume, Pavel Nyaga, 03/19/2010
- Re: [cgal-discuss] scattered point cloud volume, Sheikh Faridul Hasan, 03/20/2010
- Re: [cgal-discuss] scattered point cloud volume, t doehring, 03/21/2010
