- To:
- Subject: [cgal-discuss] 3D surfaces of buildings
- Date: Tue, 23 Mar 2010 13:10:05 +0100 (CET)
My name is Mohamed Salim, a researcher in Meteorological Institute of Hamburg
University. I would like to consult you about one problem.
Currently, we are simulating the boundary layer of Hamburg city using CFD code
and I need to produce the required mesh. The problem is that I have the data
of
the buildings in the form of STL (triangular surface with its 3D three points
and its unit vector). My question is: "Is there any program which can produce
a
solid 3D shape from the triangular surfaces (tetrahedral, hexahedral, ..etc?"
Or is there a method that I can check if a point lies inside these surfaces
(i.e., inside the building)?
- [cgal-discuss] 3D surfaces of buildings, mohamed.salim, 03/23/2010
- Re: [cgal-discuss] 3D surfaces of buildings, Mariette Yvinec, 03/23/2010
