- To:
- Subject: Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package
- Date: Tue, 23 Mar 2010 14:46:22 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=DCbNp/bMqANGxasTMMfz1G73g64SKPuSbNPz4rC/cUwzziULK/8j2jh6x41BIVLJdG gdrYGKrhqOh4qn/c9lM8wiSOaTra6eSzialKikfWfgRyIuYd+DcN5fmWFBOWqsFcbjio +BgoYtYVvCEzWbK6iYKAtuExA4+KmR0MTsKaE=
Glad I could help. The test case is unusual: I was performing refinement of more structured environments, but needed a pathological test case to prove a point. You're welcome to use the case in your test suite.
Thanks for your time.
Simon
On Tue, Mar 23, 2010 at 1:33 PM, Laurent Rineau (GeometryFactory) <> wrote:
On Tuesday 23 March 2010 11:04:35 Simon Perkins wrote:Congratulation! You have found a bug in Mesh_2! Your data set is quite
> Hi Laurent
> I've added the assertion but the problem still occurs. Here is the code. It
> produces the two different precondition errors on both CGAL 3.5.1 and 3.6.
> The call to refine_Delaunay_mesh_2 is on line 62 of trigen.cpp.
strange, because you insert in a cdt all finite edges of another one. That
uncommon data set triggers a bug in the detection of clusters of constrained
edges.
I will send you a fix of include/CGAL/Mesh_2/Clusters.h before the end of the
week.
Do you agree that your (random) data set is inserted in the CGAL test suite?
Being uncommon, it is interesting!
Laurent Rineau, PhD
- [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/09/2010
- [cgal-discuss] Re: Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/16/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Laurent Rineau (GeometryFactory), 03/16/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/23/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Laurent Rineau (GeometryFactory), 03/23/2010
- Re: [cgal-discuss] Precondition Violation in Mesh Refinement 2 Package, Simon Perkins, 03/25/2010
