- To:
- Subject: Re: [cgal-discuss] Access to CGAL source files
- Date: Tue, 30 Mar 2010 01:28:07 +0200
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=Y7Kkh/XmDQk1BW/f6JRembdQXNiQsGfQtlMQQUZU/dgytrQ9AZ3d6paw7xzfeyY95F sgNYEZCKsy+ZrnU9FtgtDWPrEWRgDPV/lUOIK11lXzISF/cikLiibpV6qxw5BAlEDp0u PZYWF16G40PGZaClRNOMSz/FCvWiBXOqHBqZ4=
CGAL is *mostly* a header only library
this is why , precompiled headers are the only means for fast compilation times
Regards,
Mohamed Yousef
Regards,
Mohamed Yousef
On 30 March 2010 00:53, Guilherme Kunigami <> wrote:
Thank you very much Avishek, I found them!
I've forgotten that templated classes definitions can' t be put in a .cpp file.
Regards,
On Mon, Mar 29, 2010 at 10:52 AM, avishek banerjee
<> wrote:
> Hi Guilherme,
> The templated versions of several algos have been in include files,
> that is where class desc have been provided !
> I hope this suffices.
> Avishek
Guilherme Kunigami
- [cgal-discuss] Access to CGAL source files, Guilherme Kunigami, 03/29/2010
- Re: [cgal-discuss] Access to CGAL source files, avishek banerjee, 03/29/2010
- Re: [cgal-discuss] Access to CGAL source files, Guilherme Kunigami, 03/30/2010
- Re: [cgal-discuss] Access to CGAL source files, Mohamed Yousef, 03/30/2010
- Re: [cgal-discuss] Access to CGAL source files, Louis Lavery, 03/30/2010
- Re: [cgal-discuss] Access to CGAL source files, Laurent Rineau (GeometryFactory), 03/30/2010
