cgal-discuss - [cgal-discuss] 3D Surface Mesh Generation
  • To:
  • Subject: [cgal-discuss] 3D Surface Mesh Generation
  • Date: Tue, 30 Mar 2010 07:00:45 +0200 (CEST)
Hi,
I have included CGAL into my application and successfully executed the two
examples in :
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
My application is a NURBS surface modeler. My application can query any Nurb
surface with a ray and return the intersection (if one exists). I understand
this is the only requirement for the CGAL library to mesh the surface? However
i do not understand how to configure the CGAL oracle so that it uses my NURBS
surface ray intersection to generate the points for the mesh?
Is it possible to post some code showing more generic use of the surface
meshing functionality? (i.e not implicit or gray level image surfaces)
Thanks in advance for any assistance,
Dougal
