cgal-discuss - Re: [cgal-discuss] 3D Surface Mesh Generation
  • To:
  • Subject: Re: [cgal-discuss] 3D Surface Mesh Generation
  • Date: Tue, 30 Mar 2010 14:20:20 +0200
On 30/03/2010 07:00,
wrote:
Hi,
I have included CGAL into my application and successfully executed the two
examples in :
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_mesher/Chapter_main.html
My application is a NURBS surface modeler. My application can query any Nurb
surface with a ray and return the intersection (if one exists). I understand
this is the only requirement for the CGAL library to mesh the surface? However
i do not understand how to configure the CGAL oracle so that it uses my NURBS
surface ray intersection to generate the points for the mesh?
Is it possible to post some code showing more generic use of the surface
meshing functionality? (i.e not implicit or gray level image surfaces)
Thanks in advance for any assistance,
Dougal
Hi Dougal,
Concerning the surface mesh generator for Nurbs the best
would be to get inspired by the remesher of polyhedral surfaces
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Surface_mesher/Chapter_main.html#Section_46.6
Codewise this means to have a look at
CGAL-3.6/demo/Polyhedron/Polyhedron_demo_remeshing_plugin_cgal_code.cpp
Note that the mesh generator doesn't do a perfect job yet
when you have sharp features. This is something we work
on for the case of polyhedral surfaces.
best regards,
andreas fabri
