- To:
- Subject: Re: [cgal-discuss] Ray_2: What does supporting_line() do?
- Date: Thu, 1 Apr 2010 23:53:01 +0200
Le Jeudi 01 Avril 2010 23:49:13, James Le Cuirot a écrit :
> Hello,
> The Ray_2 class has a function called supporting_line(). It sounds
> useful but I'm not quite sure what it does. The docs say it returns the
> line supporting r which has the same direction. What is a supporting
> line exactly?
Given a (non-degenerated) ray, there is exactly one line that contains it.
That is the supporting line of the ray.
Another example: given a triangle in 3D there is exactly one plane that
contains it, that the supporting plane.
I think you get the point, now.
Laurent Rineau, PhD
- [cgal-discuss] Ray_2: What does supporting_line() do?, James Le Cuirot, 04/01/2010
- Re: [cgal-discuss] Ray_2: What does supporting_line() do?, Laurent Rineau (GeometryFactory), 04/01/2010
- Re: [cgal-discuss] Ray_2: What does supporting_line() do?, James Le Cuirot, 04/02/2010
- Re: [cgal-discuss] Ray_2: What does supporting_line() do?, Laurent Rineau (GeometryFactory), 04/02/2010
