- To:
- Subject: Re: [cgal-discuss] Ray_2: What does supporting_line() do?
- Date: Thu, 1 Apr 2010 23:02:33 +0100
On Thu, 1 Apr 2010 23:53:01 +0200
"Laurent Rineau (GeometryFactory)"
wrote:
> > The Ray_2 class has a function called supporting_line(). It sounds
> > useful but I'm not quite sure what it does. The docs say it returns
> > the line supporting r which has the same direction. What is a
> > supporting line exactly?
> Given a (non-degenerated) ray, there is exactly one line that
> contains it. That is the supporting line of the ray.
> Another example: given a triangle in 3D there is exactly one plane
> that contains it, that the supporting plane.
> I think you get the point, now.
Hmm I wish I did. I'm lacking some background here. Doesn't a ray extend
to infinity in one direction? How can a line "contain" that?
James
- [cgal-discuss] Ray_2: What does supporting_line() do?, James Le Cuirot, 04/01/2010
- Re: [cgal-discuss] Ray_2: What does supporting_line() do?, Laurent Rineau (GeometryFactory), 04/01/2010
- Re: [cgal-discuss] Ray_2: What does supporting_line() do?, James Le Cuirot, 04/02/2010
- Re: [cgal-discuss] Ray_2: What does supporting_line() do?, Laurent Rineau (GeometryFactory), 04/02/2010
