cgal-discuss - Re: [cgal-discuss] C3T3 - Inconsistent number of cells in .mesh file and c3t3 stream output
  • To:
  • Subject: Re: [cgal-discuss] C3T3 - Inconsistent number of cells in .mesh file and c3t3 stream output
  • Date: Thu, 08 Apr 2010 18:32:11 +0200
Ramin H wrote:
Thank you. That's right. There are exactly 35274 tetrahedra with subdomain
index equal to 1.
So what are the rest tetrahedra with a zero index for?
In a few words, the c3t3 (i.e. the output mesh) is a subset of the cells of the triangulation of all vertices which are inserted by the refinement process. Thus, some cells of this underlying triangulation are not part of the c3t3. When you put the object c3t3.triangulation() into a file, you save this complete underlying triangulation.
I am trying to understand how exactly C3T3 works because I have issues with
finding surface facets and their coherent normal vectors.
Maybe this could help you if you only have one subdomain. For each surface facet, can't you get the adjacent cell which is inside the domain and then orient the normal outward to this cell ?
I appreciate your help.
-Ramin
On Thu, Apr 8, 2010 at 11:26 AM, Stephane Tayeb <
wrote:
Ramin H wrote:
Hi,
I save a c3t3 into out.mesh and it reports 35274 tetrahedra.
I save the same c3t3 using "fileStream << c3t3.triangulation()" and the
file
shows 41444 cells.
Why are these numbers inconsistent?
-Ramin
PS. The list does not allow me to attach the files (best compression size
is
1440K). I can email it if needed.
Hi Ramin,
The triangulation file contains all the tetrahedra of the triangulation,
whereas the .mesh file contains only the tetrahedra of the triangulation
which belong to the discretization of the input domain.
This explains probably why your two numbers differ. Let me know if it's not
the case (you could for example check in the triangulation file how many
tetrahedra have a non-zero subdomain index).
Stephane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
Stephane Tayeb
