cgal-discuss - Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?
  • To:
  • Subject: Re: [cgal-discuss] 'CGAL-vc90-mt.lib' Is there such a file?
  • Date: Thu, 08 Apr 2010 12:19:44 -0500
Hi A S,
I was able to compile the program by carefully following the online installation instructions from the CGAL website. As I recall, you have to install and run cmake, set your directories, and configure. Then you load the Visual Studio (i'm using vs2008) project solution and build everything with install.
there are some other details, but if you have problems look in this forum archive and you will probably find all your answers.
I'm very new to cpp and vs2008 and i was able to do it so you should have no problem.
best,
T
A S wrote:
I see that the CGAL is more or less .cpp and header files, I'm searching but can't find anything pertaining to compiling or needing to compile CGAL libraries anywhere in the manual.  Just CMake stuff, <Configure> and <Generate>.
Help.  If there's a make or build file in, or for, CGAL, I can't find it.  Or anything about it in the manual.
To:
Date: Thursday, April 8, 2010, 8:44 AM
On Thursday 08 April 2010 09:48:00 A
S wrote:
What is this 'CGAL-vc90-mt.lib'?  Does this thing
even exist in the world?
It's not in the CGAL 3.6 download.
The Windows installer of CGAL>=3.4 no longer install
precompiled libraries.
You need to compile CGAL libraries after CGAL is install.
You better read the
installation manual! ;-)
http://www.cgal.org/Manual/last/doc_html/installation_manual/contents.html
Laurent Rineau, PhD
R&D Engineer at GeometryFactory
     http://www.geometryfactory.com/
Release Manager of the CGAL Project
oo-o--o---o----o-----o------o-------o------o-----o----o---o--o-oo
Todd C. Doehring, Ph.D.
Assistant Professor
School of Biomedical Engineering
Drexel University
