cgal-discuss - Re: [cgal-discuss] Area and stream lines
  • To:
  • Subject: Re: [cgal-discuss] Area and stream lines
  • Date: Fri, 09 Apr 2010 21:53:51 +0200
  • Organization: INRIA
hi Marcos,
I think that's feasible if you go into the streamline code:
- add integer attribute to the DT vertices and update it during integration - one index per streamline
- iterate over all triangles which have only two distinct streamline indices (say index i and j) - and add their area - you should have a decent estimate of the area between streamline i and j.
Pierre Alliez
INRIA Sophia Antipolis - Mediterranee
Project-team GEOMETRICA
http://www-sop.inria.fr/members/Pierre.Alliez/
Tel: +33 4 92 38 76 77
Fax: +33 4 97 15 53 95
Marcos R. P. a écrit :
Hi, everybody!
Is possible to calculate the area between two stream-lines?
Thanks!
mrp
