- To:
- Subject: Res: [cgal-discuss] Area and stream lines
- Date: Tue, 13 Apr 2010 04:30:04 -0700 (PDT)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.br; h=Message-ID:X-YMail-OSG:Received:X-Mailer:References:Date:From:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=Re6v3lWser8NG1v5lm54C5ILsmxNACTisnEBRO6oB4fsqGD/8U/c7P/8lKjAqjLOsj7jBiLSa1BIinwvlix9p7iEV8pnT4Gcg9HqDwKzVAjEE+johlZEe5i3FJldHkXfwPQgWSQXCgPqpHDO7bslQNDJMJKZgGxj6BSYVME7mUk=;
Thank you very much, Pierre!
In fact this give me a good approximation of the area.
mrp
De: Pierre Alliez <>
Para:
Enviadas: Sexta-feira, 9 de Abril de 2010 16:53:51
Assunto: Re: [cgal-discuss] Area and stream lines
hi Marcos,
I think that's feasible if you go into the streamline code:
- add integer attribute to the DT vertices and update it during integration - one index per streamline
- iterate over all triangles which have only two distinct streamline indices (say index i and j) - and add their area - you should have a decent estimate of the area between streamline i and j.
Pierre Alliez INRIA Sophia Antipolis - Mediterranee Project-team GEOMETRICA http://www-sop.inria.fr/members/Pierre.Alliez/ Tel: +33 4 92 38 76 77 Fax: +33 4 97 15 53 95
Marcos R. P. a écrit :
Hi, everybody!
Is possible to calculate the area between two stream-lines?Thanks!mrp
- [cgal-discuss] Area and stream lines, Marcos R. P., 04/09/2010
- Re: [cgal-discuss] Area and stream lines, Pierre Alliez, 04/09/2010
- Res: [cgal-discuss] Area and stream lines, Marcos R. P., 04/13/2010
