- To:
- Subject: [cgal-discuss] error install boost on linux redhat
- Date: Tue, 13 Apr 2010 05:27:10 -0800 (PST)
I install cgal on linux redhat ,in install boost_1_38_0 for using cgal ,in
command ./configure ,following error is occur :
Building Boost.Jam with toolset gcc... tools/jam/src/bin.linuxx86/bjam
Detecting Python version... 2.4
Detecting Python root... /usr
Unicode/ICU support for Boost.Regex?... not found.
Backing up existing Boost.Build configuration in user-config.jam.2
Generating Boost.Build configuration in user-config.jam...
Generating Makefile...
please help me , thank and best regard.
View this message in context:
http://n4.nabble.com/error-install-boost-on-linux-redhat-tp1838402p1838402.html
- [cgal-discuss] error install boost on linux redhat, mahdavi, 04/13/2010
- Re: [cgal-discuss] error install boost on linux redhat, Laurent Rineau (GeometryFactory), 04/13/2010
