cgal-discuss - Re: [cgal-discuss] Voronoi 2D : convert Halfedge to Segment_2 or Ray_2
  • To:
  • Subject: Re: [cgal-discuss] Voronoi 2D : convert Halfedge to Segment_2 or Ray_2
  • Date: Tue, 13 Apr 2010 18:28:16 +0200
  • Organization: Buf Compagnie
Thank you so much, I did not think of this nice solution, it helps a lot :)
Vu, Khuong wrote:
Laure,
I don't know if CGAL can convert a Voronoi edge into a Ray or not, since an
edge may be a quadratic curve, not only a straight line. Anyway, we can solve
your problem, based on some following simple observations:
Let P is the set of all points from your input set S. If S contains
segments, P includes the end-points of those.
1. a ray R (equivalently a infinite edge) MUST be a bisector of 2 points. Let
those points be p1 and p2, and L be the line passing p1 and p2. L divides the
plane into 2 halves: h1 and h2.
2. In case of the order-1 Voronoi diagram (as CGAL provides): all points of P
MUST stay in ONE SINGLE half plane divided by L., say h1, not both. It's easy
to prove that R must direct h2. From the observation, we can have a simple
algorithm:
let p be the intersection of R and L, and s be the source of R. The direction
of R is either from s to p, or from p to s. If s is in h1, then the
direction is from s to p. Otherwise, it is from p to s.
Hope it solves your problem.
Best,
Khuong
________________________________________
Sent: Monday, April 12, 2010 10:44 AM
To:
Ray_2
Hi Khuong,
You are absolutely right. I have a diagram like this one :
http://www.olivierlanglois.net/images/voro2.jpg
which i want to bound with a Rectangle (say, the borders of the image)
I hear your solution, but the problem remains, that even if the source
or target does not exist (infinite edge), I need the direction of the
edge to calculate its intersection with a the rectangle. This is why i
want to convert this edge to Ray_2.
Moreover, if an edge is finite (i.e. if it has a source AND a target),
sometimes it will intersect this rectange as well. That is why I need to
convert it to Segment_2.
In the second case, I could create this segment from the source and
target point and test the intersection, but in the first case (infinite
edge), I cannot figure how to get this intersection if only have one
point and no direction, and cannot convert the edge to Ray_2.
I hope i have made myself clear :) Thank you for your help Khuong.
Vu, Khuong wrote:
Hi Laure,
Let me see if I understand your problem correctly. You have a set of segments
(sites), which possibly intersect with each other. You then construct the
Voronoi diagram, and test if the face of each (possible divided due to
intersections) site is close of open.
If so, you can use the function has_target or has_source to check if a
segment if infinite. Hope this helps.
Best,
Khuong
Sent: Monday, April 12, 2010 10:05 AM
To:
Subject: [cgal-discuss] Voronoi 2D : convert Halfedge to Segment_2 or Ray_2
Hi all,
I'm kind of stuck with this issue with Voronoi 2D. I know this topic has
been discussed a lot in this mailing, but I could not find a solution in
the archives.
I am getting a Voronoi diagram from successive sites insertions, then i
want to get its faces and vertices. Since i want to bound this diagram
with a convex hull, i need to get the intersection of the diagram edges
with this hull, and in this purpose i want to convert each halfedge to
Segment_2 or Ray_2 in order to test this intersection.
Here is my (simplified) code :
typedef typename CGAL::Delaunay_triangulation_2<K> DT;
typedef typename CGAL::Delaunay_triangulation_adaptation_traits_2<DT> AT;
typedef typename
CGAL::Delaunay_triangulation_caching_degeneracy_removal_policy_2<DT> AP;
typedef typename CGAL::Voronoi_diagram_2<DT,AT,AP> Voronoi;
typedef typename Voronoi::Face_iterator Face_iterator;
typedef typename Voronoi::Ccb_halfedge_circulator Ccb_halfedge_circulator;
typedef typename AT::Site_2 Site_2;
Voronoi VD;
// for each point [x,y] :
VD.insert( Site_2(x,y) );
for ( Face_iterator bf = VD.faces_begin() ; bf != VD.faces_end() ; ++bf )
Ccb_halfedge_circulator firstEdge = (*bf).outer_ccb();
Ccb_halfedge_circulator he = firstEdge;
do
CGAL::Object obj = make_object(he);
Segment_2 segment;
Ray_2 ray;
bool isSegment = ( CGAL::assign( segment, obj ) );
bool isRay = ( CGAL::assign( ray, obj ) );
// test intersection, get points, etc.
while ( ++he != firstEdge );
My problem is that isRay and isSegment always return false, even when
he->is_ray() or he->is_segment() are true.
What did i do wrong ? How can i make this conversion ?
Any hint will be greatly appreciated, thank you !
Laure
