- To:
- Subject: [cgal-discuss] mesh simplified
- Date: Wed, 14 Apr 2010 00:57:06 +0200 (CEST)
Hi
I am new in CGAL so how can I create a surface by having just vtk file format
then using simplified mesh which is mentioned in website
.for example I have coordinate 1,-1,1 and I I have vertex number in vtk file
also
so how can I create this surface in below program
#include <iostream>
#include <fstream>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Polyhedron_3.h>
#include <CGAL/IO/Polyhedron_iostream.h>
// Adaptor for Polyhedron_3
#include <CGAL/Surface_mesh_simplification/HalfedgeGraph_Polyhedron_3.h>
// Simplification function
#include <CGAL/Surface_mesh_simplification/edge_collapse.h>
// Stop-condition policy
#include
<CGAL/Surface_mesh_simplification/Policies/Edge_collapse/Count_stop_predicate.h>
typedef CGAL::Simple_cartesian<double> Kernel;
typedef CGAL::Polyhedron_3<Kernel> Surface;
namespace SMS = CGAL::Surface_mesh_simplification ;
int main( int argc, char** argv )
Surface surface;
std::ifstream is(argv[1]) ; is >> surface ;
// This is a stop predicate (defines when the algorithm terminates).
// In this example, the simplification stops when the number of undirected
edges
// left in the surface drops below the specified number (1000)
SMS::Count_stop_predicate<Surface> stop(1000);
// This the actual call to the simplification algorithm.
// The surface and stop conditions are mandatory arguments.
// The index maps are needed because the vertices and edges
// of this surface lack an "id()" field.
int r = SMS::edge_collapse
(surface
,stop
,CGAL::vertex_index_map(boost::get(CGAL::vertex_external_index,surface))
.edge_index_map (boost::get(CGAL::edge_external_index
,surface))
std::cout << "\nFinished...\n" << r << " edges removed.\n"
<< (surface.size_of_halfedges()/2) << " final edges.\n" ;
std::ofstream os( argc > 2 ? argv[2] : "out.off" ) ; os << surface ;
return 0 ;
- [cgal-discuss] mesh simplified, sahel, 04/14/2010
