- To:
- Subject: Re: [cgal-discuss] about the function "finite_adjacent_vertices"
- Date: Mon, 26 Apr 2010 20:18:13 +0800
Thank you very much! It also helps me for using other similar functions.
Lin
在 2010-04-26一的 08:16 +0200,Sebastien Loriot (GeometryFactory)写道:
> Song Lin wrote:
> > Hi,
> Hello,
> > I want to find connected groups of an alpha_shape_3 and I'm trying to
> > use this function: (my thought was first find the neighbors of a vertex
> > and then check if one neighbor vertex was linked by an edge to that
> > vertex)
> > template <class OutputIterator> OutputIterator
> > t.finite_adjacent_vertices ( Vertex_handle v, OutputIterator vertices)
> > Copies the Vertex_handles of all finite vertices adjacent to v to the
> > output iterator vertices. If t.dimension() <0, then do nothing. Returns
> > the resulting output iterator.
> > Precondition:
> > v ≠ Vertex_handle(), t.is_vertex(v).
> > But I don't know how to define an "OutputIterator vertices" type.(Sorry
> > if noob) And I can't find an example of this function. Can anyone give
> > me an example on how to use this function?
> for example:
> std::vector<Vertex_handle> adjacent_vertices;
> t.finite_adjacent_vertices(v,std::back_inserter(adjacent_vertices));
> > By the way, what does "v ≠ Vertex_handle()" mean?
> v must not be a default constructed Vertex_handle, which means that it
> must be a valid Vertex_handle.
> > Best regards,
> > Lin
Center of Computational and Systems Biology,
Institute of Biophysics, CAS.
15 Datun Road, Chaoyang District
Beijing, 100101
P.R.China
- [cgal-discuss] about the function "finite_adjacent_vertices", Song Lin, 04/25/2010
- Re: [cgal-discuss] about the function "finite_adjacent_vertices", Sebastien Loriot (GeometryFactory), 04/26/2010
- Re: [cgal-discuss] about the function "finite_adjacent_vertices", Song Lin, 04/26/2010
