cgal-discuss - [cgal-discuss] A couple of problems with 2D Minkowski sums
  • To:
  • Subject: [cgal-discuss] A couple of problems with 2D Minkowski sums
  • Date: Sun, 25 Apr 2010 20:47:59 -0400
Attached are two simple programs that demonstrate my difficulties with 2D Minkowski sums. The first one, mks_point.cpp enters into an infinite loop when attempting to calculate the Minkowski sum of one polygon with another polygon that contains only one single point. It is my expectation that the result of such a computation is merely the translation of the polygon by the point.
Secondly, and more important to me, I need to calculate the Minkowski sum of a polygon and an edge of another polygon. I am doing that by making a polygon with only two verticies. The second program shows my problem. The output is:
{ Outer boundary = [ 14 vertices: (-7 -3) (-7 -13) (-13 -13) (-13 -3) (-17 -3) (-27 -3) (-27 -17) (-3 -17) (7 -17) (7 -3) (3 -3) (7 -3) (7 -17) (-3 -17) ]
0 holes:
Which is incorrect. The last three verticies should not exist, and if you look closely, they backtrack along the path around the polygon. When I use the verticies in an OpenGL program to display the polygon, I get a nonsensical shape. If those last three verticies were not there, then the shape would be correct. It is a U shape with square corners, translated horizontally. So the vertical parts of the U shape should be thick due to the translation.
When I remove the negative signs from the Q polygon, then the output is correct.
I would appreciate some help with this. I did not see anything in the CGAL manual stating that there were restrictions on the Minkowski sum operation.
Thanks.
#include <CGAL/Cartesian.h>
#include <CGAL/minkowski_sum_2.h>
#include <print_utils.h>
typedef CGAL::Cartesian<float>                Kernel;
typedef Kernel::Point_2                             Point_2;
typedef CGAL::Polygon_2<Kernel>                     Polygon_2;
typedef CGAL::Polygon_with_holes_2<Kernel>          Polygon_with_holes_2;
int main(int argc, char* argv[])
  Polygon_2   P;
  P.push_back (Point_2 (0, 0));
  P.push_back (Point_2 (10, 0));
  Polygon_2   Q;
  Q.push_back (Point_2 (-3, -3));
  Q.push_back (Point_2 (-7, -3));
  Q.push_back (Point_2 (-7, -13));
  Q.push_back (Point_2 (-23, -13));
  Q.push_back (Point_2 (-23, -3));
  Q.push_back (Point_2 (-27, -3));
  Q.push_back (Point_2 (-27, -17));
  Q.push_back (Point_2 (-3, -17));
  Polygon_with_holes_2 sum=minkowski_sum_2(P, Q);
  print_polygon_with_holes(sum);
  return (0);
  Polygon_2   P;
  Polygon_2   Q;
  Q.push_back (Point_2 (3, 3));
  Q.push_back (Point_2 (7, 3));
  Q.push_back (Point_2 (7, 13));
  Q.push_back (Point_2 (23, 13));
  Q.push_back (Point_2 (23, 3));
  Q.push_back (Point_2 (27, 3));
  Q.push_back (Point_2 (27, 17));
  Q.push_back (Point_2 (3, 17));
  return (0);
