- To:
- Subject: Re: [cgal-discuss] A couple of problems with 2D Minkowski sums
- Date: Mon, 26 Apr 2010 21:19:28 -0400
Thanks for the help. Unfortunately, changing the kernel does not alter the output. I am still getting the same behavior using an Exact_predicate_exact_construction_kernel. That is, in the line case, the same polygon is being produced, and in the point case, the program is still going into an infinite loop.
The change I did was to add this line:
#include <CGAL/Exact_predicates_exact_constructions_kernel.h>
And change my Kernel typedef to:
typedef CGAL::Exact_predicates_exact_constructions_kernel Kernel;
wrote:
As Ben pointed out, you must use an exact-predicate and exact-construction kernel. I suggest:
CGAL::Exact_predicate_exact_construction_kernel
Quoting "Ben Supnik"
Hi JLM,
Am I right in thinking that you are using a kernel that does not have exact constructions with Minkowski sum?
I'm not 100% sure on this, but I think you need an exact construction kernel to use Minkowski sums.
cheers
Ben
J.L.M. wrote:
Attached are two simple programs that demonstrate my difficulties with 2D Minkowski sums. The first one, mks_point.cpp enters into an infinite loop when attempting to calculate the Minkowski sum of one polygon with another polygon that contains only one single point. It is my expectation that the result of such a computation is merely the translation of the polygon by the point.
Secondly, and more important to me, I need to calculate the Minkowski sum of a polygon and an edge of another polygon. I am doing that by making a polygon with only two verticies. The second program shows my problem. The output is:
{ Outer boundary = [ 14 vertices: (-7 -3) (-7 -13) (-13 -13) (-13 -3) (-17 -3) (-27 -3) (-27 -17) (-3 -17) (7 -17) (7 -3) (3 -3) (7 -3) (7 -17) (-3 -17) ]
0 holes:
Which is incorrect. The last three verticies should not exist, and if you look closely, they backtrack along the path around the polygon. When I use the verticies in an OpenGL program to display the polygon, I get a nonsensical shape. If those last three verticies were not there, then the shape would be correct. It is a U shape with square corners, translated horizontally. So the vertical parts of the U shape should be thick due to the translation.
When I remove the negative signs from the Q polygon, then the output is correct.
I would appreciate some help with this. I did not see anything in the CGAL manual stating that there were restrictions on the Minkowski sum operation.
Thanks.
Scenery Home Page: http://scenery.x-plane.com/
Scenery blog: http://xplanescenery.blogspot.com/
Plugin SDK: http://www.xsquawkbox.net/xpsdk/
X-Plane Wiki: http://wiki.x-plane.com/
Scenery mailing list:
Developer mailing list:
- [cgal-discuss] A couple of problems with 2D Minkowski sums, J.L.M., 04/26/2010
- Re: [cgal-discuss] A couple of problems with 2D Minkowski sums, Ben Supnik, 04/26/2010
- Re: [cgal-discuss] A couple of problems with 2D Minkowski sums, efif, 04/26/2010
- Re: [cgal-discuss] A couple of problems with 2D Minkowski sums, J.L.M., 04/27/2010
- Re: [cgal-discuss] A couple of problems with 2D Minkowski sums, Efraim Fogel, 04/27/2010
