cgal-discuss - Re: [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?
  • To:
  • Subject: Re: [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?
  • Date: Tue, 27 Apr 2010 08:14:41 +0200
Song Lin wrote:
Hi,
I want to check if the edge between two adjacent vertices belongs to
Alpha_shape_3:(to decide if the two vertices are in one group)
vector<Vertex_handle> adjacent_vertices;
as.finite_adjacent_vertices(vit,back_inserter(adjacent_vertices));
for (int i=0;i<adjacent_vertices.size();i++)
if(as.classify(###the edge between vit and
adjacent_vertices[i]###,0)==Alpha_shape_3::EXTERIOR)
But I found that an edge was defined as:
typedef Triple<Cell_handle, int, int> Edge;
Can I build an edge without the information of Cell_handle? If can't,
what should I do to build an edge that can be used in the function
"as.classify()"?
Best regards,
Lin
Hello,
From the manual, you can see that the class Alpha_shape_3 inherits
from its template triangulation. All triangulation in CGAL inherits from
the class Triangulation_3.
From here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html#Function_bool_is_edge6Vertex_handle_u+_Vertex_handle_v+_Cell_handle___c+_int___i+_int___j9_const;
you will find the function is_edge that will give you
the information needed to define the triple.
S.
