Re: [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?
- To:
- Subject: Re: [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?
- Date: Tue, 27 Apr 2010 21:24:26 +0800
Thank you very much!
Lin
在 2010-04-27二的 08:14 +0200,Sebastien Loriot (GeometryFactory)写道:
> Song Lin wrote:
> > Hi,
> > I want to check if the edge between two adjacent vertices belongs to
> > Alpha_shape_3:(to decide if the two vertices are in one group)
> > vector<Vertex_handle> adjacent_vertices;
> > as.finite_adjacent_vertices(vit,back_inserter(adjacent_vertices));
> > for (int i=0;i<adjacent_vertices.size();i++)
> > if(as.classify(###the edge between vit and
> > adjacent_vertices[i]###,0)==Alpha_shape_3::EXTERIOR)
> > But I found that an edge was defined as:
> > typedef Triple<Cell_handle, int, int> Edge;
> > Can I build an edge without the information of Cell_handle? If can't,
> > what should I do to build an edge that can be used in the function
> > "as.classify()"?
> > Best regards,
> > Lin
> Hello,
> From the manual, you can see that the class Alpha_shape_3 inherits
> from its template triangulation. All triangulation in CGAL inherits from
> the class Triangulation_3.
> From here:
> http://www.cgal.org/Manual/last/doc_html/cgal_manual/Triangulation_3_ref/Class_Triangulation_3.html#Function_bool_is_edge6Vertex_handle_u+_Vertex_handle_v+_Cell_handle___c+_int___i+_int___j9_const;
> you will find the function is_edge that will give you
> the information needed to define the triple.
> S.
Center of Computational and Systems Biology,
Institute of Biophysics, CAS.
15 Datun Road, Chaoyang District
Beijing, 100101
P.R.China
- [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?, Song Lin, 04/27/2010
- Re: [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?, Sebastien Loriot (GeometryFactory), 04/27/2010
- Re: [cgal-discuss] Can I build a TDS::Edge from two adjacent TDS::Vertex_handle?, Song Lin, 04/27/2010
