cgal-discuss - [cgal-discuss] Re: CGAL 3.6 first post-installation steps
  • To:
  • Subject: [cgal-discuss] Re: CGAL 3.6 first post-installation steps
  • Date: Wed, 28 Apr 2010 02:18:56 -0700 (PDT)
Hi there! Answering my own question (maybe it will help other novices like
me), in order to make this example run, I had to manually add
find_package(CGAL COMPONENTS ImageIO)
into the CmakeLists.txt, created by the script.
Another weird thing that happened during my installation is that in the
CGALConfig.cmake file I had the following lines:
set(WITH_CGAL "ON")
set(WITH_CGAL_Core "ON")
set(WITH_CGAL_ImageIO "ON")
set(WITH_CGAL_PDB "ON" )
set(WITH_CGAL_Qt3 "OFF" )
set(WITH_CGAL_Qt4 "ON" )
set(CGAL_LIBRARY "/usr/local/lib/libCGAL.so")
set(CGAL_Core_LIBRARY "/usr/local/lib/libCGAL_Core.so")
set(CGAL_ImageIO_LIBRARY "/usr/local/lib/")
set(CGAL_PDB_LIBRARY "/usr/local/lib/libCGAL_PDB.so" )
set(CGAL_Qt3_LIBRARY "/usr/local/lib/" )
set(CGAL_Qt4_LIBRARY "/usr/local/lib/" )
So the paths to ImageIO and Qt4 libraries were truncated for some reason. I
simply added the corresponding names at the end of these paths. After that
the ImageIO library was successfully hooked up by the linker.
Best of luck,
Yan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-3-6-first-post-installation-steps-tp2065667p2068843.html
