cgal-discuss - RE: [cgal-discuss] RE: Problems on segment Voronoi diagram
  • To: "" <>
  • Subject: RE: [cgal-discuss] RE: Problems on segment Voronoi diagram
  • Date: Wed, 28 Apr 2010 03:33:30 -0500
  • Accept-language: en-US
  • Acceptlanguage: en-US
I'm sure Halfedge class provides functions to retrieve the left and right
sites constructing the edge, from which you determine the edge type, i.e.,
curve or straight line. You may want to look at the third example of the
Delaunay diagram section in the manual. It has exactly the code for your
requirement.
Best,
Khuong
________________________________________
Sent: Tuesday, April 27, 2010 10:50 PM
To:
Subject: [cgal-discuss] RE: Problems on segment Voronoi diagram
Thank you very much for Menelaos Karavelas's advice, I was busy during last
three days and has just back to lab.
I tried Gmpq, this really improved the efficiency and time spent on my cases
reduced to 2/3. Here is my result on 50 segments on polyline:
GMpq insertSegments()
1.89
MP_Float insertSegments()
2.61
GMpq insertPolyline()
1.89
MP_Float insertPolyline()
2.594
However, this is only performed on Segment Delaunay Graph.
I tried 600 segments on SDG(segment Delaunay Graph) and VD (Voronoi diagram)
respectively.
The results performed on SDG is ok, the is_valid() function returns true as
well.
However, VD is not good as expected. The is_valid() function did not finish
within 20 miniutes. And I interrputed the validating process manually.
I think Vu, Khuong's analysis is reasonable, there is somthing wrong with
the Voronoi Diagram Adapter, how do you think?
Another issue is proposed in my application, I still need some advice on the
DCEL structure in CGAL.
It seems that the HalfEdge structure only gives the source and target point
, with out indicating what
type the edge is, such as line segment, line ,or parabolic arc, any way to
obtain the detail information
of the halfedges in DCEL?
Thank you.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-on-segment-Voronoi-diagram-tp2023020p2068585.html
