cgal-discuss - Re: [cgal-discuss] about dual(facet)
  • To:
  • Subject: Re: [cgal-discuss] about dual(facet)
  • Date: Wed, 28 Apr 2010 17:58:00 +0200
wrote:
Hi,
I'm using the function t.dual(Facet f). Following the documentation I
expect as result segments or rays in the 3D case and a point if the
dimension is 2. When considering a 2D complex embedded in a 3D
triangulation (for example represented by C2T3) I obtain actually segment
and rays for facets in the volume but I don't have points selecting facets
on the surface.
Can anyone help me to understand the observed behaviour?
Thanks in advance!
Hi,
Am I wrong if I suppose that you use: c2t3.triangulation().dual(f), where f is a facet such as c2t3.is_in_complex(f) == true ?
In such a case, you are in the 3D case you described, as you are calling dual() on a 3D triangulation. Thus, the dual is a segment or a ray.
I think I can't help more since I don't know the behaviour you expect. Are you trying to retrieve the circumcenter of the surface triangles ? Do you expect something else, such as the center of the surface Delaunay ball of the facet (see Surface Mesher package documentation) ?
Best,
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
