- To:
- Subject: [cgal-discuss] about dual(facet)
- Date: Wed, 28 Apr 2010 18:47:16 +0200 (MEST)
- Importance: Normal
Thank you for your prompt reply!
Am I wrong if I suppose that you use: c2t3.triangulation().dual(f), where
f is a facet such as c2t3.is_in_complex(f) == true ?
Yes, this is the requirement I set for facets inside the volume and I
obtain the expected 3D-behavior, as you stress.
Conversely, when I select surface triangles (if
((*it_facet).first->is_facet_on_surface((*it_facet).second)==true)) I
don't obtain points, but only rays (also "choosing" finite facets).
I think I can't help more since I don't know the behaviour you expect. Are
you trying to retrieve the circumcenter of the surface triangles ?
This is the first quantity I need, are you right. Actually I try to
evaluate the Voronoi surface area around each vertex generate by the
Surface mesher. So I select finite incident facets to each vertex, I check
if the triangles are on the surface and I search the circumcenters.
Best
- [cgal-discuss] about dual(facet), cecilia, 04/28/2010
- <Possible follow-up(s)>
- Re: [cgal-discuss] about dual(facet), Stephane Tayeb, 04/28/2010
