- To:
- Subject: Re: [cgal-discuss] weird performance issue
- Date: Thu, 29 Apr 2010 10:23:00 +0200
Sebastien Loriot (GeometryFactory) wrote:
Ariel Keselman wrote:But in any case it makes sense to also use: -DNDEBUG or at least -DCGAL_DNDEBUG,
Dear all,From what you describe I see no reason why CGAL would be responsible
after every Ubuntu update, I have this problem in which the
both the compilation time AND running time of my program
decrease by a factor of 2.
For compilation I use 'scons', and I link with the following
libraries:
CGAL_Core, CGAL, gmp, gmpxx, mpfr, boost_thread-mt
and with the following flags:
-O3
This issue appears to be solved after several minutes,
but I would be happy to know if there is a reason, and
a way to guarantee consistent behavior.
for that. Maybe a process was running in background and was slowing down
your system (which would explain why things were normal several minutes later).
S.
since you only mention -O3.
Michael
- [cgal-discuss] weird performance issue, Ariel Keselman, 04/29/2010
- Re: [cgal-discuss] weird performance issue, Sebastien Loriot (GeometryFactory), 04/29/2010
- Re: [cgal-discuss] weird performance issue, Michael Hemmer, 04/29/2010
