- To:
- Subject: Re: [cgal-discuss] RE: Problems on segment Voronoi diagram
- Date: Thu, 29 Apr 2010 10:13:07 +0300
I still have not had the time to take a look at it. I will get back to this issue when I have something concrete.
- m.
On 29 Apr 2010, at 04:10, Bai wrote:
OK , I got it. This can be done by identifying the type of sites on both
sides. Thank you!
By the way, do you always call the is_valid() member function of the
Voronoi Diagram? For the same set of segments more than 500, the Segment
Delaunay Graph returns true when is_valid() is called, and the same function
of Voronoi diagram may not stop runing. I think there is really sth wrong
with Voronoi Adapter.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problems-on-segment-Voronoi-diagram-tp2023020p2074901.html
- [cgal-discuss] RE: Problems on segment Voronoi diagram, (continued)
- [cgal-discuss] RE: Problems on segment Voronoi diagram, Bai, 04/23/2010
- RE: [cgal-discuss] RE: Problems on segment Voronoi diagram, Vu, Khuong, 04/23/2010
- Re: [cgal-discuss] RE: Problems on segment Voronoi diagram, Menelaos Karavelas, 04/23/2010
- [cgal-discuss] RE: Problems on segment Voronoi diagram, Bai, 04/28/2010
- RE: [cgal-discuss] RE: Problems on segment Voronoi diagram, Vu, Khuong, 04/28/2010
- [cgal-discuss] RE: Problems on segment Voronoi diagram, Bai, 04/29/2010
- Re: [cgal-discuss] RE: Problems on segment Voronoi diagram, Menelaos Karavelas, 04/29/2010
