- To:
- Subject: Re: [cgal-discuss] Subdivision_3 - Example problem
- Date: Thu, 29 Apr 2010 11:46:57 -0700
On Thu, Apr 29, 2010 at 11:07 AM, KOUMANTARIS <> wrote:
Hello,
I am having a problem loading large .OFF files (8-10 Mb). When i run any of the
subdivisions in the Subdivision_3 examples section i get an empty .OFF file as
result. Actually is not empty, it has OFF at the first line and 0 0 0 on the
second line. It runs fine with smaller files, from 1-5 Mb.
Do you have any idea why this is happening and any possible ways to fix this
problem.
thank you
Could you link a large .OFF file, so that we might be able to try and replicate the problem?
Thanks!
Thanks!
- [cgal-discuss] Subdivision_3 - Example problem, KOUMANTARIS, 04/29/2010
- Re: [cgal-discuss] Subdivision_3 - Example problem, Kevin Griffin, 04/29/2010
- Message not available
- Re: [cgal-discuss] Subdivision_3 - Example problem, George Koumantaris, 04/29/2010
