- To:
- Subject: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
- Date: Thu, 29 Apr 2010 11:29:30 -0700 (PDT)
Hi,
Thanks for the reply. The program crashes-
The point set that i have sent actually contains only 667 points.
The program you write crashes at point 987, with the point set
attached here:
http://n4.nabble.com/forum/FileDownload.jtp?type=n&id=2076004&name=points.xyz
points.xyz
So, I do think it's a bug...
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/is-fast-location-for-periodic-Delaunay-broken-tp2075170p2076004.html
- [cgal-discuss] is fast location for periodic Delaunay broken?, Ariel Keselman, 04/29/2010
- [cgal-discuss] Re: is fast location for periodic Delaunay broken?, Ariel Keselman, 04/29/2010
- Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?, Manuel Caroli, 04/29/2010
