- To:
- Subject: Re: [cgal-discuss] Regular delaunay mesh refinement
- Date: Sun, 2 May 2010 23:35:16 -0300
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :content-type; b=eVgasfIUbJrIFWc+3iQq0s+3zMylJVeFOqy+ldVZ5ti8Ohbd6sup9QEuf3aP7vu5Wi syr97br+dz0xSRERwOTyxXOvEXJymumVRqjRHFogKHrh+ETpivAFleAjT7ZnFuE3qa2o Hj5KhBiWDvRXoIuW69QPBqh4MBeBqc7nApwS4=
Thanks for answering.
The problem is that info contained in CGAL::Triangulation_vertex_
base_with_info_2 needs update as steiner vertices are added (e.g. steiner vertices' Info needs stolen voronoi area of other vertices in the same ways as described in Interpolation chapter ).
I could not find how to do that using visitors such as Refine_edges_base_with_clusters.
Thanks once again,
daniel
Thanks once again,
daniel
2010/5/2 Laurent Rineau (GeometryFactory) <>
Le dimanche 02 mai 2010 23:33:38, Daniel Oliveira a écrit :
> I'm using CGAL::Triangulation_vertex_base_with_info_2 and I need to updateThe following chapter of the CGAL manual will probably help you:
> its information with natural neighbor coordinates as triangulation are
> refined, is possible to do that with cgal?
http://www.cgal.org/Manual/last/doc_html/cgal_manual/Interpolation/Chapter_main.html
To have a good overview of all CGAL chapters, the "Overview" page of the
manual is nice:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/packages.html
Google too is a nice tool:
http://www.google.com/search?q=CGAL+natural+neighbors
The bottom of side bar of the home page of http://www.cgal.org/ has a search
tool to do a search with Google within the web site or within the manual.
Laurent Rineau, PhD
- Re: [cgal-discuss] Regular delaunay mesh refinement, Laurent Rineau (GeometryFactory), 05/01/2010
- Re: [cgal-discuss] Regular delaunay mesh refinement, Daniel Oliveira, 05/02/2010
- Re: [cgal-discuss] Regular delaunay mesh refinement, Laurent Rineau (GeometryFactory), 05/03/2010
- Re: [cgal-discuss] Regular delaunay mesh refinement, Daniel Oliveira, 05/03/2010
