- To:
- Subject: Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?
- Date: Mon, 03 May 2010 11:04:04 +0200
Hi Ariel,
I found the problem and fixed it. I'm going to verify and test the fix and then I'll send you a patch.
Thank you for your report.
Manuel
On 29/04/10 20:29, Ariel Keselman wrote:
Hi,
Thanks for the reply. The program crashes-
The point set that i have sent actually contains only 667 points.
The program you write crashes at point 987, with the point set
attached here:
http://n4.nabble.com/forum/FileDownload.jtp?type=n&id=2076004&name=points.xyz
points.xyz
So, I do think it's a bug...
- Re: [cgal-discuss] Re: is fast location for periodic Delaunay broken?, Manuel Caroli, 05/03/2010
- <Possible follow-up(s)>
