- To:
- Subject: Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror
- Date: Tue, 4 May 2010 11:30:02 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=WyAhmfE2lsNeu81/lLFPhrqQcyQDTnZKr+a+sRJ5233rV9OVAoQgxA7rpBbQs10wa4 udKaIHi83KWcWwy5enMP/sXVd8lpTtoY3Ualy/aPjvbIQ4fwYBiqgJQ3w0URUuBsaWw/ HN9drRGRF17fgO7BzYIHBYKChkLGX0ssvbhOI=
Laurent,
Do you get the same results on your machine for the cell and it's mirror if you loop over facets of the C3T3 when you mesh the polyhedral domain I provided?
Thanks,
-Ramin
On Tue, May 4, 2010 at 9:11 AM, Ramin H <> wrote:
I wanted to add that I have extended the Mesher_3 by adding one member function:
template<class C3T3, class MC, class MD>
void
Mesher_3<C3T3,MC,MD>::refine_mesh_one_step()
if ( ! cells_mesher_.is_algorithm_done() )
cells_mesher_.one_step(cells_visitor_);
And call this function at each step to track the mesh refinement and visualize each step. I hope this does not have anything to do with this problem.
-RaminOn Tue, May 4, 2010 at 8:37 AM, Ramin H <> wrote:
Here are the typedef's
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Mesh_3::Robust_intersection_traits_3<K> Geom_traits;
typedef CGAL::Polyhedron_3<Geom_traits> Polyhedron;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, Geom_traits> Mesh_domain;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
I read the Polyhedron from an .off file. This polyhedron was created by performing Boolean operation on a few other polyhedrons. If the input in consistent, then the problem is in the code.On Tue, May 4, 2010 at 7:57 AM, Laurent Rineau (GeometryFactory) <> wrote:No it is not a correct behavior. There is an inconsistency between the answersOn Monday 03 May 2010 18:43:42 Ramin H wrote:
> Hi,
> I still don't know everything about C3T3 even though I have read the
> documentation. In a 3D triangulation, let's say the cell representing a
> facet does not belong to domain (subdomain=0). If we find the mirror cell
> of this facet, should it belong to the domain (subdomain > 0) ?
> To test this idea, I wrote the following code:
> for(Facet_iterator facet_it = c3t3_.facets_begin() ;
> facet_it != c3t3_.facets_end() ;
> ++facet_it)
> Facet facet = *facet_it;
> const Facet f = c3t3_.triangulation().mirror_facet(facet);
> if( (int)(facet.first->subdomain_index()) ==
> (int)(f.first->subdomain_index()) )
> std::cerr << "Cell and it's mirror have equal subindex: " <<
> (int)(f.first->subdomain_index()) << std::endl;
> Here is some sample output:
> Cell and it's mirror have equal subindex: 1
> Cell and it's mirror have equal subindex: 0
> Is this correct behavior? If Facet_iterator is iterating over the facets on
> the surface, why a cell representing that facet and it's mirror both can
> have subdomain index equal to 1 or 0?
provided by the mesh domain oracle to the two following questions :
- does a given segment/ray intersects the boundary of the domain,
- is a given center of cell in the domain or not.
Does your domain class (CGAL::Polyhedral_mesh_domain_3 or something like that)
use a filtered (exact) kernel or an inexact one?
Laurent Rineau, PhD
- [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Ramin H, 05/03/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Laurent Rineau (GeometryFactory), 05/04/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Mariette Yvinec, 05/04/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Ramin H, 05/04/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Ramin H, 05/05/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Mariette Yvinec, 05/06/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Stephane Tayeb, 05/06/2010
- Re: [cgal-discuss] 3D meshing - Subdomain index of a cell and it's mirror, Ramin H, 05/06/2010
