cgal-discuss - Re: [cgal-discuss] Re: Neighbours list in 3D meshing
  • To:
  • Subject: Re: [cgal-discuss] Re: Neighbours list in 3D meshing
  • Date: Tue, 04 May 2010 15:26:39 +0200
Ianic wrote:
No. It is a Cell_handle pointing to:
+ an infinite cell, i.e. a cell which is incident to the infinite
vertex (you could have a look in 3D Triangulation package documentation,
and also here:
http://www.cgal.org/Manual/last/doc_html/cgal_manual/TriangulationDS_3/Chapter_main.html).
+ a finite cell which is not part of the domain discretization
So, I assume that c3t3.is_in_complex(neighbor) will issue false for both of
these cases, is that right?
Yes.
As for the facets, your suggestion is spot-on! When a circulator went over
facets it sometimes looked at them from a different cell, so they were not
present in my map. In this case I now take its mirror facet as a key for my
std::map and obtain the correct facet number. Thank you for your help,
Stephane.
Stephane Tayeb
Software engineer - INRIA Sophia Antipolis
Geometrica Project-Team
